That's what I thought, but getting into that 2nd harmonic might be difficult on a slow turning engine.
Another thing. Lets take the 24" length as an example. At ~6000 RPM you get a 10% boost, at ~4500 RPM you get a 7% boost, at ~3400 RPM you get a 4% boost. What happens in between these peaks? It would seem that if pressure peaks, it should also valley in sort of a sine wave. Perhaps there would be negative pressure at ~5250, ~3950, and ~3000 in decreasing amounts. It might make for an interesting torque curve.
Robert
'95 Ford E150 4.9L I6 Megasquirt MS1 Custom MSnS Extra
'92 Winnebago Elante 33 RQ Ford 7.5L V8 Megasquirt MS1 Custom MSnS Extra
'93 Bayliner 3288 Twin Ford 5.8L V8s (351 Windsors) converted to tuned port EFI. Megasquirt MS1 Custom MSnS Extra
