Originally Posted by drmiller100
You want to inject the gas into the transfer ports, and you want to inject starting at BDC, then delay from there.
For WOT, they often run a second injector into the crankcase just to get enough fuel at WOT.
That does not do the same thing as direct injection. You need the piston past the exhaust port before you start injection.
