Alternator vs. no alternator thread:
The use of a spare battery to reduce alt loading has merit.
I wonder if you could just manually switch the alt on/off as needed.
Late model BMWs shut off the alt when the battery reaches~80% charge.
Then the remaining 20% gets charged by putting the alt on when the brakes are applied or when the car decelerates.
This has a decelerating effect so you are actually "recovering" energy which goes to the battery.
Maybe you could do something similar - manually with a gauge and a switch???
