Old 02-01-2012, 06:37 PM   #5 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by UFO View Post
That does not do the same thing as direct injection. You need the piston past the exhaust port before you start injection.
From what I remember the marine variations used the same block with a modification for a low pressure injector to inject directly just after the valves close, not sure if that can be replicated in a shop with a system in hand from another motor. I assume a small port drilled in from the side or even top would work.
Also of the DI 2 cycles I have not yet found one in anywhere near the size # of cylinders or horsepower rating as my motor which is an issue. 3 does not work with 2 cylinders.
