Old 02-02-2012, 07:16 AM   #3 (permalink)
pete c
If I bought that jeep, the last thing I would do is lower it. It kind of defeats the whole purpose of having a jeep.
Could I ask why you are buying such a vehicle? I assume you won't be taking it off road as lowering is an option.
The jeep is a great vehicle....if you intend to use it for it's designed purpose. If your needs are an on road 4x4 wagon, the subaru makes way more sense.
If greater towing capability is a need, the jeep does make sense.
I suspect that at least a partial grill block would be fine. This vehicle was made for the rigors of off roading which means it should have more cooling capacity than needed for regular driving.
