Originally Posted by JRMichler
Or keep it simple and drop in a Volvo transmission with overdrive. That in itself should get you about 4 MPG.
I actually have a 4speed and O/D set up (driveshaft too) but the trans needs
work and momma wants an ATM. I figure if I'm swapping trans might be a good idea to get a more modern engine with a bit more torque.
the factory atm in these old dogs did not have O/D. adaptors to put an O/D atm are around $900. I'd swap the whole mess 1st.
