My old 6.2 truck had a tranny cooler about a third the size of the radiator.
All my tranny disasters came when the truck was cruising down the superslab.
In a way, locked-TC is the worst condition. The TC (with no relative motion between rotor and stator) is pumping zero fluid through the cooler. I understand newer automatics transmissions have an auxiliary fluid cooler pump.
Nothing cruises the slab like a stick.
The 700R4 is notorious for "hunting." In and out of TC lockup.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
