Old 02-03-2012, 10:50 AM   #9 (permalink)
Daox
I measured something low around 1A when I measured mine. In any case you can get away with just a switch. Mine has been installed for over a year now and works great. However a relay definitely does allow you to do some nifty things like activate it while braking. Also, if you use a normally closed relay it will fail in the closed position so if it does fail your alternator is connected.
