Originally Posted by Daox
I measured something low around 1A when I measured mine. In any case you can get away with just a switch. Mine has been installed for over a year now and works great. However a relay definitely does allow you to do some nifty things like activate it while braking. Also, if you use a normally closed relay it will fail in the closed position so if it does fail your alternator is connected.
yes that would be the best thing to do for this mod.
