Old 02-03-2012, 12:14 PM   #32 (permalink)
niky
Originally Posted by 320touring View Post
As an aside- could you LPG the Prius?
I'm pretty sure you could. My worry is keeping the coolant system warm enough to keep pressure in the lines, but since the engine in the Prius already cycles on to bring the heat in the engine up, it shouldn't be a big issue.
One issue with some cars is valve wear. But the Prius uses so little gas that it will probably be a looooong time before this becomes an issue.
But the fact that it uses so little gas means that your Return-on-investment in LPG, typically two to three years in a regular car, might take much, much longer. Especially as the LPG system turns off when the engine turns off, and the engine restarts on gasoline first, then switches to LPG when warmed up again.
EDIT: looking on the net, there are some companies that actually convert Prii. Cool.
Better, though, if the car is designed as an LPG car from the get-go, like Hyundai's Elantra LPG-electric hybrid.
