Will you be off roading in this truck ?
If so, consider a bicycle. It will be far less damaging to the Environment - air pollution, noise pollution, and overall destruction of everything you tear through.
It's great exercise and you get to see the outdoors the same way you do in a jeep, but at a slower pace that allows you to enjoy the things you likely would have run over in the jeep.
If you will not be off roading or even driving this thing off pavement, it just doesn't make any good sense to buy.
If you need it to haul stuff, or help someone move, consider simply renting a uhaul truck when the need arises. ( perhaps once every two years ?
Off roading with a bike can be just as much fun as using a jeep
