Old 02-03-2012, 07:00 PM   #52 (permalink)
fastegg
fastegg's Avatar
Lexus semi-electric
My car is a '98 Lexus LS400 4-litre V8.. If I was to run an electric water pump, electric power steering pump, electric fan... those things coupled with fuel injection pump, ignition, stereo, ECU's for everything, other power consuming do-dads which the car is full of... how many amps per hour am i up for ?
... My guess is about 85 amps. .. ... .... .....
*** and I reckon 14 volt batteries, so when they started running low, the volts probably, hopefully, won't drop below 12 volts...
... I wonder how many batteries I'd need ?
.... and a decent charger to charge them each night.... possibly even a 3 phase charger...
Name:	14 volt battery.gif
UCF20R LS400 VVTi
Lexus Mad
Last edited by fastegg; 02-03-2012 at 07:30 PM.. Reason: i keep thinking of other things... its all very ad-lib... :)
