Originally Posted by deathtrain
yes that sounds correct but what does it do when you plug everything in and remove that 7.5a fuse No. 15?
Tried this. Several things happen, not all of them good.
1) Alternator does not charge (that's what we wanted)
2) Check Engine Light with 2 codes. Sorry, codes not recorded.
3) Speedometer is disabled as the fuse powers it.
4) Fast idle and a rich mixture (reported by ScanGauge custom LBN gauge setup). That was on a fully warmed up engine.
