Old 02-04-2012, 11:42 PM   #70 (permalink)
mans
A trick that a lot of drag racers use is to cut off every other fin inside the water pump. They have less drag, more power, more miles per gallon, and adequate cooling.[/QUOTE]
which pumps are you talking about cutting the fins off? the stock pumps or the electric ones? do you mean cutting every other fin off the electric pump for lower power consumption?
