Old 02-05-2012, 06:46 AM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder.
A Kammback will work the same on an estate as on a hatchback.
With most of Europe in the freezer these days, you won't need much cooling ;-)
The upper grille can safely be closed off - many have blocked (part of) the lower grille.
Always keep an eye on temperatures when blocking grilles.
If you haven't tried coasting to slowly reduce speed - give it a try.
(I keep the engine on for power steering and power brakes , others even kill the engine)
