I hear that a lot from guys with pickups, albeit at a much lower MPG level.
My answer: you're overgeared.
The closer to "properly geared" (for max MPG) the more sensitive the vehicle is to how it is driven. You're probably leaving a lot of MPG on the table, geared as you are.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
