Originally Posted by Thymeclock
Less meaning two car lengths as opposed to originally ten. Again, it is his problem, not yours. (BTW, I've never seen a car "on three tires" - unless you are speaking metaphorically.) If your car was showing no brake lights you are contributing to a potentially unsafe situation.
I think you're confusing entering the corner versus leaving the corner. He was on my bumper (at most, a car length back) going into each corner. My guess is, because the first corner was slightly more extreme, he had a harder time maintaining speed. He seemed to try to force the issue on the second corner.
And the fact that you've never seen a car on three tires just means that you have never seen a car pushed to the limits of its suspension (usually not a good idea on public roads).
