Originally Posted by eq1
You mentioned you had a P1449 code; did you ever check what subcodes you had, the 'blinking lights' codes?
Also, when you put the sticks back in the module, would it make sense to put the highest capacity stick where the lowest one was, the second highest where the second lowest one was, and so on?
I thought the same thing. An analogy would be rotating tires to even out the wear. Rotating sticks to even out the capacity and rate of deterioration.
Maybe next time, for now congratulations on resurrecting the pack. If you have issues in the future, then at that point in time you may look to see if there is a pattern that repeats itself, which would be potentially correctible with a pack rotation strategy.
regards
Mech
