Old 02-06-2012, 10:13 AM   #93 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Old Mechanic View Post
I thought the same thing. An analogy would be rotating tires to even out the wear. Rotating sticks to even out the capacity and rate of deterioration.
Maybe next time, for now congratulations on resurrecting the pack. If you have issues in the future, then at that point in time you may look to see if there is a pattern that repeats itself, which would be potentially correctible with a pack rotation strategy.
regards
Mech
On FLA cars the battery nearest the pwm controller tends to die fastest, this may be a valid strategy (to a point)
I think most insight packs can be restored somewhat but you may end up with a tinker's pack that needs a little charge each day,
I think I could live with that, too bad the insight options around here are so blasted expensive.
