Thread: 40 mpg s10 2.2L
Old 02-06-2012, 03:04 PM   #24 (permalink)
Olympiadis
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
Originally Posted by Georgboy View Post
Delta camshafts are the guys I used for my XFI regrind, seems to be a good company.... I hope I get the 15-20 mpg increase they said they betted I would see bahahahahahah!! I would use them again. Figured you can do it on a metro, then others engines should be close to the same...
Regrinding is a good way to reduce duration and widen the lope separation a bit.
Changes in lift don't really have a large effect on MPG unless it goes so high that it causes a temporary stall in air flow which reduces velocity.
A performance valvejob will increase signal in the intake port and increase velocity. More flow with same size port = higher velocity. That's a plus for boosting up low RPM power.
