Old 02-06-2012, 03:26 PM   #77 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Old Mech -
Originally Posted by Old Mechanic View Post
How about the advertised exhaust wrap for the converter, and possibly a temp probe that would read the temp of the outer converter heat shield. Then you could drive normally where you know the cat is lit and get a reliable reading for the external temp of the heat shield.
Assuming for the moment that this temp probe would be a good candidate :
High Range Adjustable Temperature Switch with LCD - Jaycar Electronics
Are you saying that the probe would be inserted *between* the heat shield (8) and the outside of the catalytic converter (1)? :
Magnaflow Catalytic Converters - Car Sound Catalytic Converters from BestInAuto.com
That would get you as close to the cat as possible without compromising/damaging the cat.
CarloSW2
American Solar Energy Society
