Old 02-06-2012, 04:09 PM   #116 (permalink)
Ken Fry
A Legend in his Own Mind
Ken Fry's Avatar
Originally Posted by euromodder View Post
1. What's the issue ?
2. And it's done without thinking about it.
1. The issue can be seen by watching someone start out on an Ecomobile or Monotracer. Unlike a motorcycle, which the rider naturally makes vertical with respect to gravity at a stop, enclosed motorcycles (so far) list at a stop to be perpendicular to the road, which is typically crowned. So the driver has to first get the wheels directly under the CG, which requires a swerve. If the bike is leaning to the right, the driver must steer to the right. If there is a car immediately to the right, this is a problem.
In a normal motorcycle, this stuff is so easy that it requires no thought and almost no effort: even if you are leaning slightly at a stop, a tiny push to vertical is simple.
Designing a linkage that makes the enclosed motorcycle vertical with respect to gravity (by individual control of the outriggers, manually) is possible but not stunningly simple. The fact that the $80,000 Ecomobile has not sorted this out is an indication of the complexity. Adding to the problem is the fact that enclosed motorcycles tend to be heavy: the Monotracer is something like 1000 lb, if I recall.
I used to ride my brother's Harley 74 when I was 12. I was fine, on tippy toes, as long as I kept it vertical. Let it lean at all, and I quickly got to the point where I could not hold it up.
In my enclosed two wheel prototype, I had independent manual control, via foot pedals, but getting sufficient control authority (high leverage) in combination with large enough travel to quickly deploy the outriggers (low leverage) is not trivial.
Enclosed motorcycles (assuming they are like the Monotracer (low and streamlined) feel much different than a motorcycle. Because the only thing that can cause the bike to lean to the right (to turn to the right) is counter steering (steering to the left), you find that you are more conscious of counter steering. When the outriggers are down however, you steer it like a car: turn right to go right.
The course for learning to drive the Monotracer is something like a week, for good reasons.
2. You're right that many motorcyclists do not think about (nor need to think about) countersteering, etc. When they panic, however, something goes haywire, and far too many start to "think" that to avoid hitting the truck they are drifting into, they must turn the handlebars away from the truck. That banks the bike right into the front of the truck. It is the classic accident that the "push right go right" campaign of the Motorcycle Safety Council was designed to prevent.
But still there are many, even some racers, who just don't understand how to steer a motorcycle -- this is the reason for Keith Code's no BS bike.
