I'm checking in after a couple of days at my mom's w/o Internet access. I've driven a lot of highway miles, Bay Area to SoCal to ABQ. I'm going to start a new mileage log for my car, and will post the results. There's a slight mileage penalty, but it's mostly due to the cold weather and elevation gain driving to 7000' elevation, rather than ending EOC P&G. My highway technique remains unchanged since my smog testing education.
I do run a grill block (and smaller F-1 side mirrors). This morning's ~20F temperature in Flagstaff would have justified a block heater. I don't use them in coastal CA. I'm not sure there's a net gain from the electricity used to warm the coolant v. the miniscule gas savings from warming the engine up sooner.
My grill block has split upper and lower portions. I had both fully blocked this morning. About 2/3 of the way from Flagstaff to ABQ, my coolant temps rose over 204F on uphills and steady state driving, so I removed the entire upper grill block.
Driving from the Bay Area to SoCal, I noticed temps >204F 15 miles from home, so I removed 1/3 of the upper grill block. The coolant temps topped 204F climbing the Grapevine, so I pulled over and removed the remaining portion of the upper grill block.
I don't do much DFCO, but will do it soon to observe its effects on cat temps.
I appreciate the suggestions for efficiency. Assuming I implement them, I'm still left with my personal conclusion that EOC P&G is a gross polluter.
p.s. The Magnaflow cat isn't legal in CA unless it has California Air Resources Board certification. Unless I'm missing something, Magnaflow doesn't mention CARB certification for its cats.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
