Old 02-07-2012, 04:35 AM   #2 (permalink)
Frank Lee
Since it isn't a chronic issue for other Metros, yours simply has a problem you haven't found yet: alignment, wobble, seizing component, sharp edge somewhere cutting the belt, incorrect tension, glazed surfaces, or ?. It should be far easier and cheaper to fix the stock system.
