Old 02-08-2012, 10:15 AM   #4 (permalink)
straight5
EcoModding Learner
nonikname - '99 Saab 9-5 2.3t
90 day: 33.71 mpg (US)
I could not agree more with your quote.
Thanks.
The centering of the TC in relation to the flywheel is one direction, but suppose one of the tabs on the TC is bent slightly toward or away from the transmission - so that when you bolt it up one tab pulls (or pushes) the flex plate so that it spins like a warped record album. If you already have it bolted up, and can see the flywheel while its running, you might check to make sure it is running true.
ps. I don't know if the book calls for it, but I always use loctite blue on the flywheel bolts.
1999 Saab 9-5 sedan 2.3t 5speed
2013 prius 3
"God is a God who both created the universe, and also had a plan that included me as an individual human being. And that he has made it possible for me, through this series of explorations, to realize that. It is not just a philosophy, it is a reality of a relationship. "
Francis S Collins - director of the National Human Genome Research Institute
