Old 02-08-2012, 04:05 PM   #11 (permalink)
Mr. Previa
ECOModder
Mr. Previa's Avatar
RAV - '13 Toyota RAV4 XLE AWD
90 day: 27.56 mpg (US)
Exclamation Part two: Add a Solar Array for Trickle Charging
I finally received the solar panel. I mounted the solar panel on the roof rack. I got lucky with this. My roof rack has small adjustable, threaded, metal tabs that I was able to bolt the panel to. It made for a nice clean install. The roof rack also has 4 locking mechanisms that I used to help keep the panel from sliding side-to-side, just in case.
I did move the panel forward on the roof after the picture below was taken.
I ran the wires through the weather stripping at the rear lift gate. I connected the wires to a run of 14 gauge wire that connected to the charge controller. I hid the wire in the crack between the carpet and the side interior panel.
I ran another segment of wire from the charge controller to the battery.
That's it. All done. Now I am able to charge my van with sunshine.
We had over cast today and the panel was charging the battery great. It even keeps the voltage higher when the van is running!
I can't wait to see what my MPG will increase to.
3585 pounds of twisted steel.
Recreational | Active | Vehicle | 4x4
...scratch that... AWD
The Following User Says Thank You to Mr. Previa For This Useful Post:
ECONORAM (05-16-2013)
