Old 02-09-2012, 02:17 PM   #167 (permalink)
oil pan 4
I need the best of all worlds.
Light weight high power LiFePO4 batteries, with 13.2v, slightly more cranking amps than the stock starting batt setup and a lot more cranking amps compared to deep cycle batteries. I am turning a 395 cubic inch, 22:1 compression engine over.
I am building serries a 21ocv 6 amp solar panel to recharge during the day.
With a good size solar panel I plan to not need external power at all, summer or winter for normal driving around town. I will reinstall the alt belt for longer trips.
Going to install an alternator cut out switch and rig up a quick removal belt system after I get the P/S driven off its own belt.
