Old 02-09-2012, 04:10 PM   #3 (permalink)
johnunit
inverter coolant should probably changed too.
Check engine light could be all sorts of things. One common issue is over-filled oil clogging things up. Make sure the oil isn't over the "full" mark while hot.
2001 Prius - 170,000 KM - just got it (no consistent FE numbers yet)
The Following User Says Thank You to johnunit For This Useful Post:
War_Wagon (02-10-2012)
