Old 02-09-2012, 08:09 PM   #8 (permalink)
07 ThunderRoad
07 ThunderRoad's Avatar
Tow Beast - '07 Dodge 2500 Cummins Turbo Diesel Laramie
Originally Posted by Diesel_Dave View Post
Where are you getting this free fuel from? I use grocery points at Kroger, usually getting about $0.50 off per gallon for one fill up per month (which is usually all I need). Is this the type of thing that you're doing?
Yeah a belly pan should help. I've planning one, but haven't gotten around to it yet.
Depending of how much you haul stuff in the bed (or if your trailler is a 5th wheel), you might want to look into a bed cover.
Just a note as well, some people with towing trucks keep 2 fuel logs--one towing, one not. You may find that works well for you.
I don't drive my truck in the winter. I have Giant Eagle fuel perks. If you buy food or gift cards for other stores, you get $0.10 off fuel for every $50.00 you spend.
2007,5.9 / 2500Laramie,Banks 4" monster exhaust,Fleet guard 2micron fuel filter,Bilstein shocks,Boost,EGT,Diff.&Trans.temp gauges,Kicker Speakers, exterior Screamer LED&Recon Line of Fire lights,Factory step tubes,Mopar heated seats&Cold weather kit,Factory service manual.
