Thread: warmer fuel?
Old 02-10-2012, 01:20 PM   #7 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by Olympiadis View Post
[B]
A fuel system under high pressure can handle more heat, but don't forget about your fuel vapor recovery system. Heating the fuel can overwhelm the vapor control/recovery, so again contingency measures have to be taken to handle the extra vapor from the tank.
ummm you don't want to heat the tank just the lines to the injectors that way the is no effect on the vapor control/recovery system..
