Old 02-10-2012, 02:48 PM   #118 (permalink)
Ken Fry
A Legend in his Own Mind
Ken Fry's Avatar
I'm not saying this stuff works, I didn't really test it out, but I would assume that if uses 1/8th less fuel to idle that it would use less fuel throughout the RPM range...
You've written two different things.
"that if uses 1/8th less fuel to idle" means that it used 7/8 as much fuel as before
"the injectors were pulsing around 1/8th the duration" means that it used 1/8 as much fuel as before
Which did you intend?
