Mixing and matching tunes is fine as long as you know what the values mean and they are for the correct engine. If you want a custom tune get a tuner and learn how to do it. I believe that you can find the resources you need over at clubTDI or it might be FredTDI I think they are the same site. Someone there might be able to tune it for you.
I never recommend a box tune as they are just guessing with out seeing the car unless you can send them scans of the car. Also all PCM/ECUs are locked but that never stops anyone.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
