Originally Posted by Daox
A wastegate does this normally. Of course you have no intake pressure to push on the wastegate actuator anymore... I imagine you rig something up though.
daox, I believe you still can have it.
if you cap off the part of the turbo that usually goes to the engine intake.
if you leave it open , then ye sure, you'd lose it.
if necessary, u can leave a hole in the cap you've installed.
this would now give a measure of control on the turbo, and the hole would keep the turbo from becoming too restricted.(a valve could be used to adjust the size of the hole too)
please correct me if i've made a mistake
