Hi Sendler, I think you are referring to an older picture of Craig's streamling when he using a removable tail. He ended up redesigning the tail section to a one piece as he found no down side to running with the full length tail all the time.. The Ninja tail is designed so it can be removed with3 bolts, I'm not sure if the Helix tail can be removed that easily.
