Old 02-11-2012, 09:12 AM   #4 (permalink)
user removed
If the engine is not rotating the throwout bearing is not rotating. The clutch disc is spinning inside the stationary pressure plate and flywheel. Throwout bearing is in contact with the stationary pressure plate.
No appreciable wear on the t-brng other than the pressure it exerts on the non moving pressure plate.
Should not present any problem or appreciable acceleration of wear.
regards
Mech
