what would you do to make this body drag less? or have the static body be the most efficient.
for
A. cheapest
B. best looking/not seen?
![](http://estore.honda.com/assets//images/2010/element/configurations/accessories/photos/SPOILER-TAILGATE-SC_mid.jpg)
these are generic pics but mine is the same. heres some background
its a 2010 honda element SC. im thinking a belly pan will help. the floor is flat and the fuel tank and exhaust is just under it. the side skirts and rear bumper extend atleast 8-10 inches below the floor so I would assume it is some extreme drag?
luckily being it is an SC it has some improvements over the base model.
A. the body kit and a slight lowering.
B. the roof cladding sits 1.25" lower then base.
C. rear spoiler? I can be wrong but it is a flat to roof extension.it is sealed to the roof so no under air flow.(im sure it can be improved)
the upper grille is useless. the radiator sits under it so it can be sealed.
mirrors need attention as they are billboards.
im also making polycarb fog light covers to make them flush with bumper.
would a custom made device like this aid a bit in the hood to windshield transition?
I know this vehicle as a whole is a bad choice as an eco friendly car but due to my work it can carry what I need.
and the 19/24 estimate is not as bad as it could be. Im working on my driving habits. and have net 24.4 mpg as my best sofar. 14 as worst and my avg over the last 12k miles was 18mpg.
all in all its not that bad driving around town but on the highways it runs into an issue. I have no problem doing 70 ir 80+ but. after 60mph the aero kills mpg.
cruising @ 55mph @1850 rpm the scan gauge would net between 24 and 26mpg. @70mph @2500 rpm it would be getting 12-14mpg :/ and by 80 its down past 9mpg.
