Old 02-11-2012, 04:35 PM   #6 (permalink)
oil pan 4
I wouldn't run it under the car, if it rubs through on the axle or something it could cause problems. I would rather run it throught the inside of the car under the carpet or hidden by the trim.
On a rear wheel drive set up can you can drill a hole throught the transmission hump near the fire wall and be right at the starter.
