Just a few questions:
Won't you cause your brakes to overheat by covering them?
Won't you cause improper wear and tear on the tires and suspension components, not to mention dangerous braking with over inflated tires?
Won't you cook your engine and transmission covering most of the air vents?
Aren't some mods like deletion of power steering and no DLR lights just dangerous for driving?
And isn't the corrugated plastic a danger to put near the engine considering it has a low melting point and a chance to cause a fire? Or (unless I missed something) are you going to be replacing them with aluminum? Also is duck tape a realistic method to securing these things considering a all the outdoor elements and the cars high speed, plus all the highway code bylaws.
Looking to do some of the mods my self if they really have no negative effects on the car itself.
