Old 02-12-2012, 08:44 AM   #5466 (permalink)
jackbauer
jackbauer's Avatar
Several people have been asking me lately how to use the revolt 500amp control board with a hall effect throttle pedal. The procedure is simple. First you need some custom software (thanks Paul!) that lets the micro use the full 0-5v input of the adc. This also allows for the throttle range and error limits to be set using RTD.
Next the hardware. Following the attached photo , remove R10 and replace R8 and D1 with wire links. Pin 5 now outputs a +5v supply for the pedal and pin 4 is now the input from the pedal. Ground can be connected to pin 2. Just a case of disconnecting the traction supply and using RTD to setup the range. My E46 bmw pedal has been running just fine the last 9 months.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 8 Users Say Thank You to jackbauer For This Useful Post:
ace_bridger (03-28-2012), LouMan (02-12-2012), mora (05-14-2013), MPaulHolmes (02-12-2012), rayjay (02-12-2012), sawickm (02-13-2012), swoozle (02-12-2012), Zanbee (02-12-2012)
