Old 02-12-2012, 09:50 AM   #3 (permalink)
hamsterpower
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
Judging by the pictures in your garage, having an engine that was not a factory option is a big part of the problem. If you do have the SI model Del Sol, you probably have extremely sporty gearing. Mix that with the B18 non VTEC engine I see in those pictures and the short ram intake, and the cards are stacked against you. All that considered and those MPG numbers are not bad. I wonder what other mods are hiding in that engine bay.
You might try starting in second or even third gear for slow city driving.
Can you describe your P&G technique? Your fifth gear is nearly the third gear in most eco cars. Also these Honda engines go into fuel enrichment fairly low on % of throttle. I have the B16 engine and my SGII shows 70% LOD at 25% throttle or less during P&G.
