Old 02-12-2012, 08:05 PM   #6 (permalink)
hamsterpower
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
As you have a '94, unless you converted it to OBDII scan guage will not work. You will need an MPGuino or similar.
Try to find a stock intake pipe and filter box. That will, likely help more than the smaller exhaust. Consider an LS transmission, I got mine off ebay very cheap. The ratios are better matched to your engine and better for economy, but sporty enough to still enjoy the car you have.
There is a difference from loading the engine and going for peak power. Like I said earlier. Mine only needs 20 -25 % throttle to see 70%+ LOD at low RPMs. Many say this is ideal for Hondas of this era. 50% throttle is a bit high and probably deep in fuel enrichment. Ease off a bit and try P&G from 40 to 30 when you can.
