Old 02-13-2012, 09:11 AM   #15 (permalink)
mans
Originally Posted by serialk11r View Post
In addition if you're running them at max temp, the ones I've seen put out 15V or so which is too high. If you wire that straight to the battery you'll end up bleeding off a few percent of the precious power through internal resistance.
u sure? dont alternators charge at 14+ volts anyway and lose a drop as a result?
so 15v shouldn't be too terrible
