Just got my USFRA membership in the mail, today
The newsletter that came with it did say what Aerohead said about the 130/150 club. They did mention a clarification for bikes about factory/dealer installed items, but, where you're shooting for streamliner anyway, Redyaris, I don't think it effects you
Other progress, I have a 1500 watt coolant heater installed, and promptly broke the cheap-a$$ "y" that came with it the 4th time I used it. New "y" is installed and will be run to/from work to help get the air out of the system( again). I'm collecting cable actuated valves to direct flow to/from the WVO tank when that comes around.
Edit- I also have the 12 volt transfer pump from Harbor Freight and have changed both front axles. All 4 bearings, rear brakes/drums, and full alignment to go.
