02-13-2012, 07:51 PM
Pokémoderator
BHarvey -
More on same :
http://www.federalmogul.com/NR/rdonl...tion_FINAL.pdf
FRANKFURT, September 13, 2011 … Federal-Mogul Corporation (NASDAQ: FDML) will introduce at this year’s IAA (Frankfurt Auto Show, Hall 4.1, Stand E15, September 13-16, 2011)
its highly innovative Advanced Corona Ignition System (ACIS), a breakthrough technology for fuel efficiency and emissions reduction that significantly outperforms conventional spark-ignition systems. Federal-Mogul’s ACIS is currently undergoing development with several customers and has enabled an up to 10-percent fuel efficiency improvement over standard spark ignition in development testing.
Corona ignition creates a significantly larger high-intensity plasma ignition source, spread throughout the combustion chamber, when compared to conventional spark ignition systems.
The ACIS technology provides for more thorough combustion and enables advanced combustion strategies like lean burn, highly diluted mixtures and very high exhaust gas recirculation (EGR), further increasing fuel efficiency. The company’s ACIS utilizes materials and design strategies to facilitate high-volume production implementation on current and new engine architectures.
Advanced Corona Ignition System Hi-Res Photos
CarloSW2
