May I suggest adding a "frost heater" to help the warm up.
Don't forget to clean the turbo actuator and the intake regularly.
I wouldn't recomend changing the tune. If its a Rocketchip or Malone, they usually improve the MPG as welll as power. Kerma, it depends on if its the regular or the Q tune.
Only good synthetic oil. Shell is the preferred over here.
Be religious about timing belt changes.
