Old 02-14-2012, 12:54 AM   #147 (permalink)
niky
Originally Posted by IamIan View Post
As I said ... I went the direction of two things ... the limits of current science ... and the limits of current technology ... what is possible ... in contrast you focused instead on the averages from average devices.
There's a difference between a technological limit and natural law. The law of thermodynamics is not a technological limit.
And the limit is, once you've converted energy two to three times, you're never going to end up with enough energy to adequately power the process creating it or to effectively offset it. Hybrid-electric works only because it allows you to completely shut off the ICE when you don't need it. Hydrogen injection doesn't. It's just adding an extra step and an extra set of losses which are better spent simply storing that electricity in a battery.
The Following User Says Thank You to niky For This Useful Post:
UFO (02-14-2012)
