i had a 2001 for 5 years. the check engine light came after some month first and after the years it was a dayly issue. the reading was some kind of "catalytic converter out of norm" and the garage says cat change.
finaly i bought a metal cat at ebay for 80 euro and had to weld it in place. everything was fine.
check the airco with UV-light. the condenser is often leak and expensive.
check the thrunk key and remote.
