Old 02-14-2012, 09:48 PM   #4 (permalink)
sgtlethargic
I think I'd want to be certain of the gear ratio. Find out how to determine it on your truck (stamped on the gear(s) or count teeth?) and pull the cover. I'd probably reuse the gear oil, unless you want to go with synthetic or something else.
Or, maybe the data plate has that info.
The Following User Says Thank You to sgtlethargic For This Useful Post:
Ben Johnson (02-11-2013)
