Originally Posted by Titanium
Thanks for the tip on the egr ports under the fuel rail. How do you clean them?
I would post a link but I dont have enough posts. Just google "hx egr cleaning" Their is a great DIY from tegger dot com. I just did this and it cleared up my CE light
They were PLUGGED! I chose not to replace the gaskets as they looked good to me and the one behind the rail is a metal plate ($50 @ dealer ouch!) And when you pull the rail up just make sure the injectors dont come out of the rail and you wont have to replace the o-rings. Just check for leaks when you are all done with the job!
