[QUOTE=drmiller100;285551]wow! what a great idea on the angle grinder!
QUOTE]
An angle grinder is very high rpm, I don’t think the gears would hold up long at all. You might want to try something like a Hole-Hog. In the electrical industry we actually use them (with additional gear reduction) as cable pullers. They are incredibly robust and would probably get you closer to the rpm you would need.
